Old 27-Jan-2015, 19:25
DangerousD DangerousD is offline
Bikes: Hypermotard 1100s
Brake discs - what fits?
As you will see from an earlier post, I'm deep in the process of servicing the brakes on the hyper, so my question for tonight is, do the front discs from any other model fit?
DD
Old 31-Jan-2015, 17:31
Fruitbat's Avatar
Fruitbat Fruitbat is offline
Bikes: Hypermotard, 600ss
Mood: Positively pensive
IIRC when I was looking 18 months ago I couldn't find any readily available equivalent. 305mm dia. means they're not exactly common. Some folk use spacers to move the caliper out to suit 320mm discs and this was the route I was going, albeit using a single 320mm (as per the Hyper prototype) and new master cylinder, until I found that 'older' versions of 305mm Braking discs were available at a reasonable price on Italian EBay. Only a minor redesign of the carrier so I bit the bullet. I think Galfer also do a 305mm set but have seen one or two reports on Ducati.ms of people having warping issues with them.
eg http://www.ebay.it/itm/COPPIA-DISCHI...em418d db4a33
About £230 inc post. Later design about £70 more...
Old 31-Jan-2015, 18:57
Hmm, I do like the sound of the 320's - I do like to be different.
Is the diameter the only difference with other models or there an offset / bolt spacing to worry about too?
DD
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:44.
