Old 08-Aug-2014, 18:23
dunlop0_1's Avatar
998 wiring woes
Right. I fitted the 998 loom to the bike no problem apart from......... The kill switch/starter does not work. Flick the switch (replaced key ignition) and everything comes on, oil light, fuel pump, relays but the kill switch and starter button are not in the loop, in fact I can disconnect the main round plug for the front harness with no effect? Also there is a small 2 pin white plug next to the relays which I have no idea what it is for.
I hate electrics help please
Neil
Old 08-Aug-2014, 18:35
dunlop0_1's Avatar
Just had a thought.
Are the 998 ignition relays specific?
Old 09-Aug-2014, 09:25
dunlop0_1's Avatar
Not the relays.
So the pump primes, manually bridge solenoid to turn over and you get one spark and no fuel
Also does not matter if the side stand switch is bridged or not
Old 10-Aug-2014, 11:09
dunlop0_1's Avatar
Sorted.
Turns out that the 998 pump primes on the key and Ducati in there wisdom changed one wire in the front harness.
Got to love my drawings though LOL. Feckin hate wiring.
Old 23-Aug-2014, 17:33
The Hammer's Avatar
The Hammer The Hammer is offline
Bikes: 1198, 748S, 900SS, SP1, Blade, 600RR, SV650N, RG125
Mood: Hungry
Dont you know talking to yourself is the first sign of madness? Glad you got it sorted, that looked like a nightmare.
Old 24-Aug-2014, 08:13
dunlop0_1's Avatar
Yep all sorted no thanks. To be honest it was an archive post from 10 years ago on DSC that helped me out.
Old 07-Sep-2014, 08:41
funkatronic funkatronic is offline
sorry for the thread hijack but how wildly different would a 1098 or 749/999 loom be seeing as they use the same ECU
sure some things will be in slightly different places and dash is different, but could looms for these bikes be adapted to fit the 998? they are certainly more available
Old 07-Sep-2014, 11:39
dunlop0_1's Avatar
Kev Ellis is yer man to ask but the canbus system the 749/999 uses I think is also on the 1098 so the loom differences could be substantially different?
998 main loom is rarer than rocking horse s**t. I managed to get two recently, one for the bike and one spare but they where not cheap.
  #9
Old 07-Sep-2014, 12:12
chrisw's Avatar
chrisw chrisw is offline
Bikes: 999 Mono/1198S
These bikes use CanBus the 998 doesn't
  #10
Old 07-Sep-2014, 22:05
The 749/999 setup is very similar to that of the 848/1098/1198 using mainly the same connections on the ECU and minor changes to the dash, partly due to the 999 dash using built in buttons to change settings etc, whereas the 1098 setup uses the left hand switch gear.
I am converting both my 998R and my 998 Hybrid to the 1098 dash and Harness. Although I could reprogram a standard ECU to run them I will be going with a Nemesis ECU on both of them
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:25.
